This Product Selection Guide contains information to help select products in the Programmable Unijunction category on DigiKey.com
Programmable unijunction transistors (PUTs) are a relative of Silicon Controlled Rectifier (SCR) devices, having a characteristic behavior somewhat like a unidirectional DIAC with a user-configurable threshold voltage. While useful for creating low frequency oscillator and timing functions, SCR triggering applications, and others, alternative techniques for addressing such needs have gained greater favor.
SelectionCharacteristics
Voltage: Typically this represents the maximum voltage rating to which a device will meet its given specifications. Exceeding this voltage rating may damage the device and other system components.
Power Dissipation (Max): Characterizes the amount of electrical power dissipation in a device that produces a specified internal device temperature (often the rated maximum) under specified operating conditions.
Voltage - Output: The maximum output voltage the device can produce across the gate-cathode connection in reverse bias operation, while the device is providing its programmed output.
Voltage - Offset (Vt): Characterizes the difference between an applied “programming” voltage and the resulting peak anode voltage on a device’s operating curve.
Current - Valley (Iv): The current flow through the device at which the resulting voltage across the device is at a minimum; the lowest point in the device’s V-I curve.
Current - Peak: Current flow through the device at the peak of its characteristic V-I curve; the current flow required to cause the device to enter its negative resistance region.
ProductExamples
| MFR PART # | CMPP6028 TR PBFREE |
| DIGIKEY PART # | 1514-CMPP6028TRPBFREETR-ND - Tape & Reel (TR) |
| MANUFACTURER | Central Semiconductor Corp |
| DESCRIPTION | Programmable Unijunction Transistor (UJT) 40V 167 mW TO-236-3, SC-59, SOT-23-3 |
| MFR PART # | 2N6028 PBFREE |
| DIGIKEY PART # | 1514-2N6028PBFREE-ND |
| DESCRIPTION | Programmable Unijunction Transistor (UJT) 40V 300 mW TO-226-3, TO-92-3 (TO-226AA) |
SchematicSymbol
