This Product Selection Guide contains information to help select products in the Lighting, Ballast Controllers category on DigiKey.com
Products in this family are used to implement control and regulation functions necessary or useful for the operation of non-LED lighting agents such as fluorescent, electroluminescent, and HID lamps. The specific function set incorporated into a given device varies with the intended use, and available products may or may not incorporate resources for direct manipulation of the power supplied to the driven load.
SelectionCharacteristics
Frequency: Indicates the operating frequency range of the device.
Voltage - Supply: Typically represented by a range, this indicates the low and high voltage limits that one can expect in standard operation. Voltages outside this range may damage the device and other system components.
Current - Supply: This represents the maximum current to which a device will meet its given specifications. Exceeding this current may damage the device and/or other system components.
Current - Output Source/Sink: The maximum amount of current that can be output by the device. If two figures are given, the first is the current output when the device is sourcing current, while the second is the current output when the device is sinking current.
Dimming: Indicates if a device includes provisions for varying the electrical output delivered to a load in an end application. May also describe the means by which a desired output set point is communicated to a device.
ProductExamples
| MFR PART # | MAX14521EETG+ |
| DIGIKEY PART # | MAX14521EETG+ -ND |
| MANUFACTURER | Analog Devices Inc./Maxim Integrated |
| DESCRIPTION | EL Lamp Driver Controller 400Hz Yes 24-TQFN (4x4) |
| MFR PART # | IR2156STRPBF |
| DIGIKEY PART # | IR2156SPBFTR-ND - Tape & Reel (TR) |
| MANUFACTURER | Infineon Technologies |
| DESCRIPTION | Ballast Controller Controller 36kHz ~ 44kHz No 14-SOIC |
| MFR PART # | MIC4827YMM |
| DIGIKEY PART # | 576-1803-5-ND |
| MANUFACTURER | Microchip Technology |
| DESCRIPTION | EL Lamp Driver Controller 60Hz ~ 1kHz No 8-MSOP |
| MFR PART # | L6574 |
| DIGIKEY PART # | 497-7252-5-ND |
| MANUFACTURER | STMicroelectronics |
| DESCRIPTION | CFL/TL Controller Controller 60kHz ~ 120kHz Yes 16-DIP |
MediaLinks
Articles
Articles on Ballast Controllers
TechForum
TechForum posts on Ballast Controllers
