This Product Selection Guide contains information to help select products in the Barrel Connector Accessories category on DigiKey.com
Products in this family are ancillary to or supportive of barrel-style connector products, including things such as mounting hardware, dust covers or caps, insulators, and similar items. Note that in this case, both common versions of the barrel plug concept are referenced; both the cylindrical connectors having multiple connection points along their length most commonly found on headphones, and the tubular style with concentric inner and outer contacts, commonly found on small wall mounted AC-DC converters.
SelectionCharacteristics
Accessory Type: The type, style, or nature of the accessory.
Number of Positions: The total number of electrical conductors the device has.
Color: The dominant color of the device.
ProductExamples
| MFR PART # | MJ-3502-NUT |
| DIGIKEY PART # | CP-3502-NUT-ND |
| MANUFACTURER | CUI Devices |
| DESCRIPTION | Connector Nut For MJ-3502 Silver |
| MFR PART # | 55-00111 |
| DIGIKEY PART # | 839-1695-ND |
| MANUFACTURER | Tensility International Corp |
| DESCRIPTION | Connector Cap (Cover) For Power Jack |
| MFR PART # | 56-00003 |
| DIGIKEY PART # | 839-1443-ND |
| DESCRIPTION | Connector Sleeve For Black |
