This Product Selection Guide contains information to help select products in the Prototype Boards Perforated category on DigiKey.com
Products in this category are used as a platform for circuit construction in hobby, experimental, and similar settings where adaptability is desired. Characterized by having a series of holes drilled through their thickness at regular intervals, they may also include a solderable conductive layer around these holes, which may or may not be interconnected, depending on the nature of a specific product. Often used for constructing circuits based on through-hole component packaging, similar products lacking perforation are more commonly used for circuit development using surface mounted components.
SelectionCharacteristics
Proto Board Type: Indicates intended board application or usage.
Plating: Indicates which type of plating the board bears, if any.
Pitch: Indicates the center-to-center spacing between adjacent holes.
Circuit Pattern: Describes the pattern of copper plating and interconnection (if any) between holes on the board.
Edge Contacts: Indicates the quantity and pitch of any card edge contacts provided.
Hole Diameter: Indicates the nominal diameter of the holes on the board.
Size / Dimension: The physical dimensions of the device. Usually given in Length by Width, in Inches (Millimeters).
Board Thickness: Indicates the nominal thickness of the circuit board material from which a product is constructed.
ProductExamples
| MFR PART # | EXN-23403-PCB |
| DIGIKEY PART # | 377-2626-ND |
| MANUFACTURER | Bud Industries |
| DESCRIPTION | Breadboard, General Purpose Plated Through Hole (PTH) Pad Per Hole (Round) 0.100" (2.54mm) |
| MFR PART # | PRT-12702 |
| DIGIKEY PART # | 1568-1083-ND |
| MANUFACTURER | SparkFun Electronics |
| DESCRIPTION | Breadboard, General Purpose Plated Through Hole (PTH) 5 Hole Pad (Both Sides) 0.100" (2.54mm) |
| MFR PART # | SBBSM2120-1 |
| DIGIKEY PART # | SBBSM2120-1-ND |
| MANUFACTURER | Chip Quik Inc. |
| DESCRIPTION | Breadboard, Surface Mount Plated Surface Mount Pad (Square) 0.100" (2.54mm) |
| MFR PART # | 201-0106-01 |
| DIGIKEY PART # | 1988-1076-ND |
| MANUFACTURER | Schmartboard, Inc. |
| DESCRIPTION | Breadboard, General Purpose Non-Plated Through Hole (NPTH) Pad Per Hole (Round) |
MediaLinks
Blogs
Breadboards and Prototype Boards
Prototyping with Modules
Building Cleaner Perfboard Projects Using These Simple Tips
TechForum
Copper clad prototype board - copper thickness
Breadboard Circuit Stability
Definitive Guide to Breadboarding Circuits
