This Product Selection Guide contains information to help select products in the Banana and Tip Connector Accessories category on DigiKey.com
Banana and Tip Connector Accessories are supportive items used with banana connectors. Accessory types include adapters, mounting bases, nuts, shorting bars, sleeves, standoffs, or terminal rings. They can be used with standard or miniature banana jacks, standard binding posts, or test jacks.
SelectionCharacteristics
Accessory Type: The type, style, or nature of the accessory.
Specifications: Where applicable. Indicates unique characteristic(s) of the accessory.
ProductExamples
| MFR PART # | 4654-0 |
| DIGIKEY PART # | 501-1951-ND |
| MANUFACTURER | Pomona Electronics |
| DESCRIPTION | Connector Mounting Base, Double (10 pack) For Banana Jacks, Standard Black Base |
| MFR PART # | 4115 |
| DIGIKEY PART # | 501-1505-ND |
| DESCRIPTION | Connector Shorting Bar For |
| MFR PART # | CT2667-0 |
| DIGIKEY PART # | CT2667-0-ND |
| MANUFACTURER | Cal Test Electronics |
| DESCRIPTION | Connector Standoff For Banana Jacks, Standard Black |
