This Product Selection Guide contains information to help select products in the Components - Motors category on DigiKey.com
SelectionCharacteristics
Assembly Configuration: Indicates how much assembly is already done when the device is provided to the customer.
Motor Type: Indicates the form factor of the motor.
Horsepower: Indicates the horsepower rating of the motor.
Output Phases: Indicates how many output phases the device was designed for use with.
Current Rating (Amps): This rating indicates the nominal amount of current you would expect the device to draw during normal operation.
RPM: Indicates the number of times the fan blade rotates every minute.
Speed: Indicates the number of speed settings available.
Color: The dominant color of the device.
Material: Indicates the material composition of the device.
Approval Agency: An indication that the product meets the minimum safety standards of an approving agency. These agencies are either government entities or private third-party labs that protect consumer safety.
ProductExamples
| MFR PART # | RP7004 |
| DIGIKEY PART # | 3539-RP7004-ND |
| MANUFACTURER | Global Industrial |
| DESCRIPTION | 1/3HP PSC Ball Bearing For 30" Wall Fans |
| MFR PART # | 292651-53-48-49motor |
| DIGIKEY PART # | 3539-292651-53-48-49motor-ND |
| MANUFACTURER | CD |
| DESCRIPTION | 1/2HP For 292648, 292649, 292651, 292653 |
| MFR PART # | ACMOT |
| DIGIKEY PART # | 3539-ACMOT-ND |
| MANUFACTURER | TPI |
| DESCRIPTION | 1/4HP Totally Enclosed For 24", 30" Fans |
