This Product Selection Guide contains information to help select products in the Pockels Cells category on DigiKey.com
Laser Optic Pockels Cells are used to generate short pulse, but high intensity laser beams. These can be filtered by the wavelength, aperture, maximum beam diameter, crystal AR, and more.
SelectionCharacteristics
Wavelength: Indicates the wavelength the device was designed for use with.
Aperture: The size of the opening through which the laser beam passes within the pockels cell.
Maximum Beam Diameter: The diameter of the maximum usable beam.
Crystal AR: The type of anti-reflection (AR) coating used on the crystal or optical element of the pockels cell.
Crystal Material: The type of crystal used in the construction of the pockels cell’s optical element.
| MFR PART # | 8450-309-200-1 |
| DIGIKEY PART # | 1601-8450-309-200-1-ND |
| MANUFACTURER | Excelitas Technologies |
| DESCRIPTION | CPC 8 IM POCKELS CELL |
| MFR PART # | 8451-301-000-96 |
| DIGIKEY PART # | 1601-8451-301-000-96-ND |
| DESCRIPTION | CIQS 8 SG POCKELS CELL |
| MFR PART # | 8450-302-135-0 |
| DIGIKEY PART # | 1601-8450-302-135-0-ND |
| DESCRIPTION | PC POSITIONER 35 |
| MFR PART # | 8451-301-000-92 |
| DIGIKEY PART # | 1601-8451-301-000-92-ND |
| DESCRIPTION | LM 10 SG 50OHM POCKELS CELL |
