This Product Selection Guide contains information to help select products in the Prisms category on DigiKey.com
Optical Prisms are devices made of transparent material that use precise angles and geometric shapes to analyze and reflect light. These can be filtered by optic size, wavelength, material, and more.
SelectionCharacteristics
Optic Size: Indicates the physical dimensions of the prism.
Wavelength: Indicates the range of wavelengths with which the prism is designed to operate.
Optic Material: Indicates the material from which a prism is made.
Coating: The thin optical coating applied to the prism’s surface to enhance its reflective or transmissive properties over specific wavelength ranges.
| MFR PART # | G339959000 |
| DIGIKEY PART # | 1601-G339959000-ND |
| MANUFACTURER | Excelitas Technologies |
| DESCRIPTION | RIGHT ANGLE PRISM ARB2/RAGV; N-B |
| MFR PART # | G339947000 |
| DIGIKEY PART # | 1601-G339947000-ND |
| DESCRIPTION | RIGHT ANGLE PRISM; FUSED SILICA; |
| MFR PART # | G339909000 |
| DIGIKEY PART # | 1601-G339909000-ND |
| DESCRIPTION | RIGHT ANGLE PRISM; N-BK7; LXH=16 |
