This Product Selection Guide contains information to help select products in the Beamsplitters category on DigiKey.com
Beamsplitters (Beam Splitters) are components that split light at a specified point. These are used in various optic systems including fiber optics. They can be filtered by the type (either cube or plate) and the wavelength.
SelectionCharacteristics
Wavelength: Typically this indicates the wavelengths of the light spectrum the device was designed for use with.
| MFR PART # | G335510000 |
| DIGIKEY PART # | 1601-G335510000-ND |
| MANUFACTURER | Excelitas Technologies |
| DESCRIPTION | BEAMSPLITTER CUBE VIS; N-BK7; L= |
| MFR PART # | G344173000 |
| DIGIKEY PART # | 1601-G344173000-ND |
| DESCRIPTION | BEAMSPL. PL. VIS-NIR; D=22.4X31. |
| MFR PART # | G344142000 |
| DIGIKEY PART # | 1601-G344142000-ND |
| DESCRIPTION | BEAMSPL. PL. VIS-NIR; BXL=15X20; |
