This Product Selection Guide contains information to help select products in the Laser Modulators category on DigiKey.com
Laser Modulators are devices used to manipulate the optical beam in a predefined way depending on the modulator type. These can be filtered down by type, wavelength, aperture, and more.
SelectionCharacteristics
Modulator Type: Indicates the style and configuration of the device.
Wavelength: Indicates the wavelength(s) of light the device is designed for use with.
Aperture: The dimensions of the opening through which the laser beam passes within the modulator.
Crystal AR: The type of anti-reflection (AR) coating used on the crystal or optical element of the modulator.
Crystal Material: The type of crystal used in the consturction of the modulator’s optical element.
Power (Watts): Typically this rating indicates the nominal amount of power you would expect the device to consume during normal operation.
| MFR PART # | 8451-209-000-08 |
| DIGIKEY PART # | 1601-8451-209-000-08-ND |
| MANUFACTURER | Excelitas Technologies |
| DESCRIPTION | ADAPTER PM-C-BB FOR 1" MIRROR |
| MFR PART # | 8451-800-000-14 |
| DIGIKEY PART # | 1601-8451-800-000-14-ND |
| DESCRIPTION | SINE AMPLIFIER |
| MFR PART # | 8451-800-000-25 |
| DIGIKEY PART # | 1601-8451-800-000-25-ND |
| DESCRIPTION | DIV20 MOD CONNECTION CABLE KIT |
| MFR PART # | 8450-202-301-8 |
| DIGIKEY PART # | 1601-8450-202-301-8-ND |
| DESCRIPTION | LM13 UNIVERSAL MODULATOR, 950-11 |
| MFR PART # | 8451-209-000-06 |
| DIGIKEY PART # | 1601-8451-209-000-06-ND |
| DESCRIPTION | PM-C-BB PHASE MODULATOR |
