This Product Selection Guide contains information to help select products in the Laser Diodes, Laser Modules - Laser Delivery, Laser Fibers category on DigiKey.com
Laser Diode and Laser Module Delivery Systems are devices used to focus the lasers in a laser system.
SelectionCharacteristics
Length: Indicates the length of the fiber.
Wavelength: Indicates the wavelength(s) of light produced.
Power (Watts): The maximum continuous output power a device is designed to produce.
Input Connector: Indicates the style/form of the connector used to supply power to a device.
Output Connector: Indicates the style/form of connector through which the device supplies its output signal.
Features: These are different capabilities or properties of the device such as kineMATIX.
ProductExamples
| MFR PART # | 15301 |
| DIGIKEY PART # | 1601-1038-ND |
| MANUFACTURER | Excelitas Technologies |
| DESCRIPTION | LASER MODULE 780NM 70MW |
