This Product Selection Guide contains information to help select products in the Machine Vision - Control/Processing category on DigiKey.com
Machine vision control and processing modules are chassis, DIN rail or panel mount devices used as camera controllers, code readers, data storage, lighting controllers, multiuse controllers, or sensors in machine vision imaging systems. They are differentiated by voltage supply, number of channels, and output types such as NPN, NPN/PNP, PhotoMos, and PNP.
SelectionCharacteristics
Controller Type: Indicates the style and configuration of the device.
Output: Indicates the type of electrical signal the device provides, such as NPN or Photomos.
Number of Channels: Indicates the number of output channels the device provides.
Voltage - Supply: An indication that the product meets the minimum safety standards of an approving agency. These agencies are either government entities or private third-party labs that protect consumer safety.
Features: These are different capabilities or properties of the device such as a display.
ProductExamples
Click here for example items
