This Product Selection Guide contains information to help select products in the Controllers - PLC Modules category on DigiKey.com
A programmable logic controller (PLC) module is an industrial digital computer which has been ruggedized and adapted for the control of manufacturing processes, such as assembly lines, or robotic devices, or any activity that requires high reliability control and ease of programming and process fault diagnosis.
SelectionCharacteristics
Number of Inputs and Type: Indicates the number of signal input circuits with which a device is equipped, and whether those inputs process applied signals as continuous (analog) or discrete (digital) values.
Number of Outputs and Type: For devices having built-in outputs, indicates the number of such outputs and the manner of their implementation.
Voltage - Supply: Typically represented by a range, this indicates the low and high voltage limits which one can expect standard operation. Voltages outside this range may damage the device and other system components.
Termination Style: Selection of termination style used to connect the device to a system, such as screw terminals or USB.
Features: These are different capabilities or properties of the device such as a display or thermistor.
ProductExamples
| MFR PART # | 750-536 |
| DIGIKEY PART # | 2946-750-536-ND |
| MANUFACTURER | WAGO Corporation |
| DESCRIPTION | Output Module DIN Rail 24VDC |
| MFR PART # | NX-OD3256 |
| DIGIKEY PART # | Z9873-ND |
| MANUFACTURER | Omron Automation and Safety |
| DESCRIPTION | Output Module DIN Rail |
| MFR PART # | AFP0RE32T |
| DIGIKEY PART # | 1110-3159-ND |
| MANUFACTURER | Panasonic Industrial Automation Sales |
| DESCRIPTION | Input, Output (I/O) Module DIN Rail |
| MFR PART # | ADAM-6250-B |
| DIGIKEY PART # | 1165-1443-ND |
| MANUFACTURER | Advantech Corp |
| DESCRIPTION | Input, Output (I/O) Module Chassis Mount |
| MFR PART # | FC6A-T16P1 |
| DIGIKEY PART # | 1885-1346-ND |
| MANUFACTURER | IDEC |
MediaLinks
Articles
What Is a PLC?
Product Training Modules
Solutions for PLC (Programmable Logic Controller) I/O Modules
