This Product Selection Guide contains information to help select products in the 3D Printers category on DigiKey.com
3D printers are rapid prototyping machines that use composite thermoplastic filaments to construct fused deposition three-dimensional models. They are characterized by their open or closed framework, manufacturer’s series, interface type, power supply, filament size, print speed, bed size, and print height. Interface types include SD card, USB, and Wi-Fi.
SelectionCharacteristics
Working Dimensions: The maximum printing area available.
Interface: Indication of which interface(s) or protocol(s) are used by the device to communicate with other components in the system.
Voltage - Supply: Typically represented by a range, this indicates the low and high voltage limits which one can expect standard operation. Voltages outside this range may damage the device and other system components.
Features: These are different capabilities or properties of the device such as PCB printer.
Contents: All that is included with the part.
ProductExamples
| MFR PART # | 3D45-01 |
| DIGIKEY PART # | 2017-1005-ND |
| MANUFACTURER | Dremel |
| DESCRIPTION | DREMEL 3D45 IDEA BUILDER 3D PRIN |
| MFR PART # | P5010059 |
| DIGIKEY PART # | 1890-P5010059-ND |
| MANUFACTURER | Makeblock Co., LTD. |
| DESCRIPTION | MCREATE W/O LASER ENGRAVER |
| MFR PART # | KT-PR0057 |
| DIGIKEY PART # | 1942-KT-PR0057-ND |
| MANUFACTURER | LulzBot |
| DESCRIPTION | NORTH AMERICA ONLY - LULZBOT TAZ |
| MFR PART # | ENDER-3 S1 PRO |
| DIGIKEY PART # | 4095-ENDER-3S1PRO-ND |
| MANUFACTURER | Shenzhen Creality 3D Technology Co., Ltd |
| DESCRIPTION | 300C HIGH-TEMP,TPU,PETG SUPPORTE |
MediaLinks
Videos
How To Clear A Clogged 3D Printer Nozzle
Articles
3D Printing Techniques
Prototype to Production Additive Manufacturing
More Articles on 3D Printers
Blogs
Why Does Your 3D Printer Nozzle Clog?
How to Clean and Maintain Your 3D Printer Nozzle
Harness 3D Calibration Prints to Improve Print Quality
How to Print Dual Colors using a Single Extruder 3D Printer
More Blogs on 3D Printers
TechForum
Tech Tip - Small detailed 3D printed parts not sticking to your print bed?
TechTip - Color Mixing in your design with 3D filament
3D Catan (Magnetic)
3D printed Ice Fishing Rod Grips
More TechForum posts on 3D Printers
