This Product Selection Guide contains information to help select products in the 3D Printers category on DigiKey.com
3D printers are rapid prototyping machines that use composite thermoplastic filaments to construct fused deposition three-dimensional models. They are characterized by their open or closed framework, manufacturer’s series, interface type, power supply, filament size, print speed, bed size, and print height. Interface types include SD card, USB, and Wi-Fi.
SelectionCharacteristics
Working Dimensions: Indicates the maximum length, width, and height the printer can accommodate in its printing area, defining the maximum allowable size of any given single print.
Interface: Indicates the communication protocol used to control the printer.
Voltage - Supply: Typically represented by a range, this indicates the low and high voltage limits which one can expect standard operation. Voltages outside this range may damage the device and other system components.
Features: These are different capabilities or properties of the device such as PCB Printer
Contents: Describes the physical contents, items, and peripherals that the device ships with.
ProductExamples
| MFR PART # | KT-PR0050NA |
| DIGI-KEY PART # | 1942-1128-ND |
| MANUFACTURER | LulzBot |
| DESCRIPTION | TAZ PRO 3D PRINTER NORTH AMERICA |
| MFR PART # | 3D45-01 |
| DIGI-KEY PART # | 2017-1005-ND |
| MANUFACTURER | Dremel |
| DESCRIPTION | DREMEL 3D45 IDEA BUILDER 3D PRIN |
| MFR PART # | P5010059 |
| DIGI-KEY PART # | 1890-P5010059-ND |
| MANUFACTURER | Makeblock Co., LTD. |
| DESCRIPTION | MCREATE W/O LASER ENGRAVER |
| MFR PART # | ENDER-3 S1 PRO |
| DIGI-KEY PART # | 4095-ENDER-3S1PRO-ND |
| MANUFACTURER | Shenzhen Creality 3D Technology Co., Ltd |
| DESCRIPTION | 300C HIGH-TEMP,TPU,PETG SUPPORTE |
MediaLinks
Videos
How To Clear A Clogged 3D Printer Nozzle – ATM Quick Take
Articles
Affordable 3D Printing Opens New Opportunities from Product Development to Customer Support
Prototype to Production Additive Manufacturing
Blogs
Designing for 3D Printing: Tips and Tricks
Why Does Your 3D Printer Nozzle Clog?
Storage Solutions for 3D Printing Filaments
Warped Prints? Try these Quick Tips with Your Next 3D Print
Advanced 3D Printing Tips and Tricks
Tips for 3D-Printing with Dissolvable Support Structures
Popular 3D Printing Materials and When to Use Them
TechForum
Making a DIY 3D-Printer Run Silent
TechTip - Color Mixing in your design with 3D filament
Pause / E-Stop button addition to my Prusa MK3S
Tech Tip - Small detailed 3D printed parts not sticking to your print bed?
Adding a Touch Screen to Prusa MK3S
3D Printing - Aaron’s Hardware Choices
