This Product Selection Guide contains information to help select products in the Canopies, Shelters and Sheds category on DigiKey.com
SelectionCharacteristics
Type: The type, style, or nature of the product.
Color: The dominant color of the product.
Construction: Indicates the material composition of the product.
Frame Color: The dominant color of the frame of the product.
Manual or Motorized: Indicates the method by which the canopy is extended or retracted.
Minimum Working Height: Indicates the minimum height the product is designed to be mounted at.
Mounting Space (Inches): Describes the distance from the mounted surface that should be clear for proper operation.
Projection From Wall (Inches): The distance the item protrudes from the wall during proper operation.
Weight: Indicates the weight of the product.
ProductExamples
| MFR PART # | B1972809 |
| DIGIKEY PART # | 3539-B1972809-ND |
| MANUFACTURER | IndustrialSupplies.com |
| DESCRIPTION | Linen/Almond/White Aluminum/Steel Patio Retractable Awning |
| MFR PART # | 602191WH |
| DIGIKEY PART # | 3539-602191WH-ND |
| MANUFACTURER | Global Industrial |
| DESCRIPTION | White Portable Straight Leg |
| MFR PART # | B977210 |
| DIGIKEY PART # | 3539-B977210-ND |
| MANUFACTURER | Picnic Time |
| DESCRIPTION | Blue/Gray/Silver Polyester Cove Sun Shelter |
| MFR PART # | B977228 |
| DIGIKEY PART # | 3539-B977228-ND |
| DESCRIPTION | Navy Polyester Oniva Seat |
