This Product Selection Guide contains information to help select products in the Decor category on DigiKey.com
SelectionCharacteristics
Type: The type, style, or nature of the product.
Assembly Configuration: Indicates whether the product comes fully assembled and ready to use or if assembly is required.
Construction: Indicates the material composition of the product.
Color: The dominant color of the product.
Height (Inches): Indicates the overall height of the product.
ProductExamples
| MFR PART # | B1598775 |
| DIGIKEY PART # | 3539-B1598775-ND |
| MANUFACTURER | Adjust-A-Gate |
| DESCRIPTION | White Powder Coat Steel/Rubber Wheel Swivel Ground Gate Wheel |
| MFR PART # | B1598774 |
| DIGIKEY PART # | 3539-B1598774-ND |
| DESCRIPTION | White Powder Coat Steel/Rubber Wheel Drop Rod Kit |
| MFR PART # | B1598770 |
| DIGIKEY PART # | 3539-B1598770-ND |
| DESCRIPTION | White Powder Coat Steel For Vinyl Fence |
