This Product Selection Guide contains information to help select products in the Pneumatics, Hydraulics - Shock Absorbers, Dampers category on DigiKey.com
Pneumatic and hydraulic shock absorbers and dampers are used to absorb and dissipate energy. Types include gas springs, linear dampers, rotary dampers, shock absorbers, speed controllers, and more.
SelectionCharacteristics
Technology: Indicates how the device is mitigating the shock/impact.
Operation: Indicates the direction of motion the item is designed to act. Also indicates if the item is designed to resist forces acting on it.
Stroke Length: The maximum rated travel distance of the actuator.
Length - Extended: The length of the item with its actuator in its extended state.
Impact Velocity: The maximum speed of impact the device is designed to handle.
Impact Capacity per Cycle: The maximum force per impact the item is designed to handle.
Actuation Force: The rated value of force that can be applied to the item in a steady state.
Reset Time: The time it takes the device to return to a fully ready state.
Reset Force: The force the device applies to its actuator to get to a full ready state.
Features: These are different capabilities or properties of the device such as cushioned start or high temperature seals.
Cushioning: Indicates if the device has cushioning and how it is implemented.
ProductExamples
| MFR PART # | RFRT-G2-101-G2 |
| DIGIKEY PART # | RFRT-G2-101-G2-ND |
| MANUFACTURER | Essentra Components |
| DESCRIPTION | DAMPER ROTARY SNAP IN BLK |
| MFR PART # | DYEF-G8-M6-Y1 |
| DIGIKEY PART # | 2171-DYEF-G8-M6-Y1-ND |
| MANUFACTURER | Festo Corporation |
| DESCRIPTION | SHOCK ABSORBER |
| MFR PART # | RFRT-G2-101-G1 |
| DIGIKEY PART # | RPC3190-ND |
