This Product Selection Guide contains information to help select products in the Blade Type Power Connector Accessories category on DigiKey.com
Blade power connectors are characterized by the incorporation of relatively thick, flat contacts that make contact with a mating connector over a relatively large surface area, so as to be able to effectively transport relatively high amounts of current through a mated contact pair. Accessory products for such connectors are ancillary to or supportive of their use or assembly, including such things as dust covers, retaining pins, mounting brackets, and others.
SelectionCharacteristics
Accessory Type: The type, style, or nature of the accessory.
Specifications: Where applicable. Indicates unique characteristic(s) of the accessory.
Color: The dominant color of the device.
Material: Indicates the material composition of the device.
ProductExamples
| MFR PART # | 110G17 |
| DIGIKEY PART # | 2243-110G17-ND |
| MANUFACTURER | Anderson Power Products, Inc. |
| DESCRIPTION | Connector Retaining Pin For Powerpole® 15, 30, 45 Series |
| MFR PART # | 1510760012 |
| DIGIKEY PART # | WM14984-ND |
| MANUFACTURER | Molex |
| DESCRIPTION | Connector Terminal Position Assurance (TPA) For EXTreme Guardian Female Housing |
| MFR PART # | 1470G1-BK |
| DIGIKEY PART # | 2243-1470G1-BK-ND |
| DESCRIPTION | Connector Receptacle Frame For Powerpole® 15, 30, 45 Series |
| MFR PART # | 5921-BK |
| DIGIKEY PART # | 2243-5921-BK-ND |
| DESCRIPTION | Connector Reducing Bushing For Powerpole® 120 Series |
