This Product Selection Guide contains information to help select products in the Flat Ribbon Cables category on DigiKey.com
Flat Ribbon Cables are a series of single conductor wires placed parallel to each other and molded together. Most ribbon cables are color coded for pin one usually red in color. The cable types are Flat cable, Flat Jacket, Ground Plane, Round Jacket, Split Conductor, Flat Twin Axial, and Flat Twisted Pair with the number of conductors ranging from 2 to 154 and pitch ranging from 0.017” (0.43mm) to 0.394” (10.00mm).
SelectionCharacteristics
Cable Type: Indicates the physical form or structure of the cable.
Number of Conductors: The number of individual conductive channels available in the cable.
Pitch: Indicates the center-to-center spacing between adjacent conductors.
Length: Indicates the length of the cable.
Wire Gauge: Indicates the gauge rating of the individual conductors in the ribbon.
Conductor Strand: Indicates the number and size of the strands of which each conductor in a cable/wire is composed; a value of 7/30 for example would indicate that each is formed from seven 30 AWG strands. All else equal, conductors formed from larger numbers of smaller strands tend to be more flexible.
Shielding: Whether or not the device possesses an electrically insulating barrier that helps to reduce or eliminate electromagnetic interference.
Jacket Color: Indicates the color of the outermost insulation layer of the cable.
Ribbon Thickness: Indicates the measurement of the cable from top to bottom, i.e. its ‘thin’ dimension.
Ribbon Width: Defines the measurement of the cable from side to side, i.e. its ‘wide’ dimension.
Jacket (Insulation) Material: Indicates the material used for the outermost jacketing of the cable.
Voltage: Typically this represents the maximum voltage rating to which a cable will meet its given specifications. Exceeding this voltage rating may damage the device and other system components.
Operating Temperature: Recommended operating temperature, typically given in a range or as a maximum. Exceeding these temperatures may affect performance or damage the cable and other system components.
Ratings: Minimum performance standards of the cable, which are typically set by a third party.
Features: These are different capabilities or properties of the device such as hi-flex and zippable.
ProductExamples
| MFR PART # | 1000570021 |
| DIGIKEY PART # | 1454-1000570021-DS-ND |
| MANUFACTURER | Molex - Temp Flex |
| DESCRIPTION | Flat Ribbon Cable Natural 20 Conductors 0.025" (0.64mm) Flat Cable Enter Number of Feet in Order Quantity |
| MFR PART # | 3365/10 100 |
| DIGIKEY PART # | 3M157849-100-ND |
| MANUFACTURER | 3M |
| DESCRIPTION | Flat Ribbon Cable Gray 10 Conductors 0.050" (1.27mm) Flat Cable 100.0’ (30.48m) |
| MFR PART # | AWG28-10/F/300 |
| DIGIKEY PART # | AE10M-300-ND |
| MANUFACTURER | Assmann WSW Components |
| DESCRIPTION | Flat Ribbon Cable Multiple 10 Conductors 0.050" (1.27mm) Flat Cable 300.0’ (91.44m) |
| MFR PART # | 1700/40 100 |
| DIGIKEY PART # | 3M157910-100-ND |
| MANUFACTURER | 3M |
| DESCRIPTION | Flat Ribbon Cable Multiple 40 (20 Pair Twisted) Conductors 0.050" (1.27mm) Flat Twisted Pair 100.0’ (30.48m) |
MediaLinks
TechForum
DigiKey Value Add Capabilities > Rectangular Cable Assemblies
DigiKey Value Add Capabilities > Custom IDC Rectangular Cable Assemblies - Interconnect / Cable Assemblies
