This Product Selection Guide contains information to help select products in the Seals - Cord Stock category on DigiKey.com
Cord Stock is pre-cut O-Ring material used to create custom O-Rings. This can be filtered by material, cross-section shape, width, hardness, color, operating temperature, length, and more.
SelectionCharacteristics
Material: Indicates the material composition of the cord.
Cross Section Shape: Indicates the shape of the cord when viewed as a cross section.
Width/Cross Section: The width of the cross section of the cord.
Color: The dominant color of the cord.
Hardness: Indicates typical material hardness and measurement scale. Higher numbers within a scale correlate to harder/firmer material.
Length: Indicates the length of the cord.
ProductExamples
| MFR PART # | ZUSA-RC-866 |
| DIGIKEY PART # | 4753-ZUSA-RC-866-ND |
| MANUFACTURER | USA Sealing |
| DESCRIPTION | Buna-N Cord Stock - 0.250" Cross |
| MFR PART # | ZUSA-RC-555 |
| DIGIKEY PART # | 4753-ZUSA-RC-555-ND |
| DESCRIPTION | X-Profile Buna-N Cord Stock - 0. |
| MFR PART # | ZUSA-RC-97 |
| DIGIKEY PART # | 4753-ZUSA-RC-97-ND |
| DESCRIPTION | Square Profile Buna-N Cord Stock |
