This Product Selection Guide contains information to help select products in the RF Front End (LNA + PA) category on DigiKey.com
Products in this family are integrated circuits that integrate one or more of the functions commonly found in the portion of a radio frequency (RF) signal chain that is connected to the system’s antenna, such as a low-noise amplifier (LNA) and programmable amplifier (P A). The actual functionality incorporated into any given device varies, with devices targeting relatively narrow applications typically integrating a larger portion of the requisite signal chain than those intended to be more flexible in their application.
SelectionCharacteristics
RF Type: Indicates the general application space or communications standard for which a device is intended for use.
Frequency: The frequency or frequencies this product is designed to be compatible.
Features: Identifies important product attributes that are intstrumental in finding a suitable selection.
Package / Case: The protective case on an electronic component which allows for easy handling, installation, and protects the device. This is what we determined is the closest industry standard to the supplier device package. Typically, it is best to use the actual dimensions from the datasheet rather than to go by this terminology when designing your circuit.
ProductExamples
| DigiKey Part Number | 863-1802-2-ND | |
| Manufacturer | Skyworks Solutions Inc. | |
| Manufacturer Product Number | SKY66111-11 | |
| Description | IC FEM BLE 2.4GHZ 20MCM | |
| Datasheet | Click Here |
| DigiKey Part Number | 2129-NJG1156PCD-TE1TR-ND | |
| Manufacturer | Nisshinbo Micro Devices Inc. | |
| Manufacturer Product Number | NJG1156PCD-TE1 | |
| Description | GPS FRONT-END MODULE | |
MediaLinks
Videos
SKY65933/943 GNSS Low-Noise Amplifier FEM
SKY66112-11; 802.15.4, ZigBee®/Thread/Bluetooth® 5
SKY66403-11; 2.4 GHz ZigBee®/Thread/Bluetooth® Front-End Module
Front-end Module for LPWAN, LoRa, IoT and Industrial Applications
