This Product Selection Guide contains information to help select products in the Thermostats - Mechanical - Industrial category on DigiKey.com
Mechanical Thermostats are designed to keep components safe in situations where there is an excessive amount of temperature. Components in this family will open or close a circuit that they are installed in when the Switching temperature (Adjustable, 14°F to 500°F) of the device is exceeded. The Reset temperature ranges are Manual Reset, One Shot, and 20°F to 440°F with Current ratings of 0.045 A to 25 A. These are made for use in an industrial setting.
SelectionCharacteristics
Circuit: Describes device function in terms of a number of poles and throws, as is typical for mechanical switches. For more information please see: Switch Basics, Examples of Pole and Throw
Switching Temperature: The nominal temperature at which a device’s output changes state. Actual temperature switch points are subject to manufacturing tolerances and hysteresis effects.
Reset Temperature: The temperature at which an actuated thermostat is rated to return to its resting (low-temperature) state.
Current Rating - AC: The maximum AC current the device is rated to interrupt, under the manufacturer’s stated test conditions.
Current Rating - DC: The maximum DC current the device is rated to interrupt, under the manufacturer’s stated test conditions.
Tolerance: Characterizes the extent of permitted variability of overall device temperature measurement among samples of a given part number, resulting from variations in manufacturing.
Switching Cycles: The number of actuation cycles at rated current that a device is expected to withstand.
Termination Style: Selection of termination style used to connect the device to a system, such as quick connect or wire leads.
ProductExamples
| MFR PART # | OHD3-60B |
| DIGIKEY PART # | 399-12178-ND |
| MANUFACTURER | KEMET |
| DESCRIPTION | THERMOSTAT 60DEG C SPST-NC MODUL |
| MFR PART # | 2455RC-90820387 |
| DIGIKEY PART # | 480-5869-ND |
| MANUFACTURER | Honeywell Sensing and Productivity Solutions |
| DESCRIPTION | THERMOSTAT 150DEG C SPST-NC CYL |
| MFR PART # | C53GAB110A-095Y |
| DIGIKEY PART # | 1862-1017-ND |
| MANUFACTURER | Sensata Technologies |
| DESCRIPTION | THERMOSTAT 43DEG C SPST-NO CYL |
MediaLinks
Videos
Honeywell 2455RC Auto Reset Thermostats | DigiKey Daily
Articles
KEMET’s New Thermorite® Temperature Sensor with Built-In ON/OFF Reed Switch
