This Product Selection Guide contains information to help select products in the Thermostats - Solid State category on DigiKey.com
Solid state thermostat products are semiconductor-based temperature detection devices that produce a two-state output, the state of which changes in response to the measured temperature exceeding a fixed limit or falling outside a defined window. Devices with pre-set threshold temperatures as well as programmable/configurable thresholds are available.
SelectionCharacteristics
Trip Temperature Threshold: Indicates if a device output is active when sensed temperature is below a setpoint (“cold”) or above a setpoint (“hot”).
Switching Temperature: The nominal temperature at which a device’s output changes state. Actual temperature switch points are subject to manufacturing tolerances and hysteresis effects.
Accuracy: Manufacturer’s specified measurement error limits across a specified temperature range.
Current - Output (Max): The maximum amount of current that can be output by the device.
Output Type: Describes the method of how the device provides the output.
Output: Describes the relative direction the output values move when the device activates.
Output Function: Indicates what a device’s output signals are intended to represent, and the logic sense (active low vs. active high) of these signals.
Selectable Hysteresis: Indicates if a device’s hysteresis level (amount that temperature must travel past the device set point to cause a change in output) is user configurable.
Features: These are different capabilities or properties of the device such as programmable or shutdown mode.
Voltage - Supply: Typically represented by a range, this indicates the low and high voltage limits which one can expect standard operation. Voltages outside this range may damage the device and other system components.
Current - Supply: This represents the maximum current to which a device will meet its given specifications. Exceeding this current may damage the device and/or other system components.
ProductExamples
| MFR PART # | MCP9509HT-E/OT |
| DIGIKEY PART # | MCP9509HT-E/OTTR-ND - Tape & Reel (TR) |
| MANUFACTURER | Microchip Technology |
| DESCRIPTION | Thermostat Programmable Active Low Open Drain SOT-23-5 |
| MFR PART # | MAX6510HAUT+T |
| DIGIKEY PART # | MAX6510HAUT+TTR-ND - Tape & Reel (TR) |
| MANUFACTURER | Analog Devices Inc./Maxim Integrated |
| DESCRIPTION | Thermostat Programmable Active High, Active Low Open Drain SOT-6 |
| MFR PART # | LM26CIM5-TPA/NOPB |
| DIGIKEY PART # | LM26CIM5-TPA/NOPBTR-ND - Tape & Reel (TR) |
| MANUFACTURER | Texas Instruments |
| DESCRIPTION | Thermostat 85°C Active Low Open Drain SOT-23-5 |
