Thermostat
I am looking for resettable temperature Switch (Thermostat) for below temperature ranges
  1. open 150 °F Close 120 °F
  2. open 180 °F Close 50 °F
  3. open 115 °F Close 30 °F
I m looking for compact model
We only have options for the first temperature switch range you require. Here are a couple links to some options for temperature switches that open at 150 °F and close 120 °F:
Thermostats - Mechanical - Industrial | Temperature Sensors | Electronic Components Distributor DigiKey
Thermostats - Mechanical | Temperature Sensors | Electronic Components Distributor DigiKey
