This Product Selection Guide contains information to help select products in the FFC, FPC (Flat Flexible) Connector Accessories category on DigiKey.com
FFC, FPC (Flat Flexible) Connector Accessories are items used with FFC, FPC connectors like a Bridge Splice, Cover, Ground Plate, Jack Screw, or Plate to be used with DF 19, FF series, FFC/FPC Cables, Flat Flex connectors, Flat Flex Contacts, Receptacle Housing or 501786 and 501864 series.
SelectionCharacteristics
Type: The type, style, or nature of the accessory.
Number of Positions: The number of positions on the connector the accessory was designed for use with.
ProductExamples
| MFR PART # | 88617-2 |
| DIGIKEY PART # | A114582-ND |
| MANUFACTURER | TE Connectivity AMP Connectors |
| DESCRIPTION | Connector Jack Screw For Receptacle Housing |
| MFR PART # | 5017835009 |
| DIGIKEY PART # | WM9066-ND |
| MANUFACTURER | Molex |
| DESCRIPTION | Connector Cover For 501786 and 501864 Series |
| MFR PART # | 5017843008 |
| DIGIKEY PART # | WM12827-ND |
