This Product Selection Guide contains information to help select products in the FFC, FPC (Flat Flexible) Connector Assemblies category on DigiKey.com
Products in this family are interconnect products used in conjunction with Flat Flexible Cable (FFC) and Flexible Printed Circuit (FPC) materials and are predominantly of the sort which performs a cable-to-board interconnect function, being mounted to a printed circuit board and provide both electrical connection and mechanical retention for an inserted FFC or FPC cable.
SelectionCharacteristics
Flat Flex Type: Indicates the type(s) of interconnect material with which a connector is designed for use.
Connector/Contact Type: Indicates geometry of flex cable contacts within connector for board-mounted products, or connector style for free-hanging products.
Number of Positions: Indicates the number of distinct conductors presented at a connector’s mating interface and the number of electrical contact points present within a connector.
Pitch: Indicates the center-to-center spacing between adjacent pins.
Termination: Describes the shape or standard configuration of a device’s electrical connection(s).
FFC, FCB Thickness: Indicates the nominal thickness or thickness range of the interconnect material accommodated by a connector.
Height Above Board: Indicates how far the device will extend above the surface to which it has been attached.
Locking Feature: Indicates the style of mechanism(s) for cable retention incorporated into a connector.
Cable End Type: Describes the cable end treatment/geometry accommodated by a connector. Used for polarization, retention, etc.
Contact Material: Indicates the material composition of the contacts.
Contact Finish: Indicates the finish/plating material applied to the contacts of the device.
Housing Material: Indicates the material composition of the housing.
Actuator Material: Indicates the material composition of the actuator.
Features: These are different capabilities or properties of the device such as a board lock, EMI shielded, or solder retention.
Voltage Rating: Typically this represents the maximum voltage rating to which a device will meet its given specifications. Exceeding this voltage rating may damage the device and other system components.
Material Flammability Rating: Ensures compliance with the relevant UL Flammability Rating.
UL94 Small Scale Flammability - Relative Comparison
Image from UL FLAMMABILITY – WHAT IT MEANS IN THE UL PRODUCT RECOGNITION PROCESS (faa.gov) Please see their website for more information.
ProductExamples
| MFR PART # | 5052781033 |
| DIGIKEY PART # | WM20869TR-ND - Tape & Reel (TR) |
| MANUFACTURER | Molex |
| DESCRIPTION | 10 Position FFC, FPC Connector Contacts, Bottom 0.020" (0.50mm) Surface Mount, Right Angle |
| MFR PART # | 528081071 |
| DIGIKEY PART # | WM3767TR-ND - Tape & Reel (TR) |
| DESCRIPTION | 10 Position FFC, FPC Connector Contacts, Vertical - 1 Sided 0.039" (1.00mm) Surface Mount |
| MFR PART # | 65801-004LF |
| DIGIKEY PART # | 609-2160-ND |
| MANUFACTURER | Amphenol ICC (FCI) |
| DESCRIPTION | 4 Position FFC, FPC Connector Receptacle 0.100" (2.54mm) Free Hanging (In-Line) |
| MFR PART # | HLW10S-2C7LF |
| DIGIKEY PART # | 609-1823-ND |
| DESCRIPTION | 10 Position FFC, FPC Connector Contacts, Vertical - 1 Sided 0.039" (1.00mm) Through Hole |
MediaLinks
Videos
Hirose FH52 Series Connector Insertion
Omron’s XF3M Rotary Backlock Connector
Product Training Modules
FFC-FPC Cables and Connectors Interactive Guide
FFC/FPC Connectors (0.50 and 1.00 mm Pitch)
TechForum
AVX / Kyocera FFC Connectors +/A+ Suffix
