This Product Selection Guide contains information to help select products in the Raw Materials - Foam category on DigiKey.com
SelectionCharacteristics
Shape: Indicates the physical form of the product.
Material: Indicates the material composition of the product.
Thickness: Indicates the overall thickness of the product.
Width: Indicates the overall width of the product.
Length: Indicates the overall length of the product.
Diameter: Indicates the diameter of the product.
Density: Indicates the mass per unit of volume of the product.
Firmness: Indicates the amount of pressure the product wan withstand without deforming. Measured in PSI (Pounds per Square Inch).
Color: The dominant color of the product.
Features: These are different capabilities or properties of the product such as adhesive backing or flame-retardant.
Operating Temperature: Recommended operating temperature, typically given in a range or as a maximum. Exceeding these temperatures may affect performance or damage the product and other system components.
ProductExamples
| MFR PART # | ZUSANSR-193 |
| DIGIKEY PART # | 4753-ZUSANSR-193-ND |
| MANUFACTURER | USA Sealing |
| DESCRIPTION | Neoprene Foam Strip with Acrylic |
| MFR PART # | ZUSA-XPE-151 |
| DIGIKEY PART # | 4753-ZUSA-XPE-151-ND |
| DESCRIPTION | Red Cross-Linked Polyethylene Fo |
