This Product Selection Guide contains information to help select products in the IGBT Modules category on DigiKey.com
Insulated-gate bipolar transistors (IGBTs) are three-terminal power semiconductor devices primarily used as electronic switches that combine high efficiency and fast switching. As modules, IGBTs are configured as asymmetrical bridges, boost, buck and brake choppers, full-bridge, three-level and three-phase inverters. Some have built-in NTC thermistors for temperature monitoring. IGBT modules are differentiated by max power, collector current, collector-emitter breakdown voltage and configuration.
SelectionCharacteristics
IGBT Type: Indicates distinctions of internal device construction that influence tradeoffs among various aspects of device performance.
Configuration: Indicates the circuit topology of the module, defining its outputs and behavior.
Voltage - Collector Emitter Breakdown (Max): The maximum voltage value the device can sustain at its collector without risking damage.
Current - Collector (IC) (Max): The maximum current value the device can sustain at its collector without risking damage.
Power - Max: Typically this represents the maximum power rating to which a device will meet its given specifications. Exceeding this power rating may damage the device and other system components.
Vce(on) (Max) @ Vge, Ic: Characterizes the maximum voltage that appears across a device’s collector and emitter terminals, measured with the indicated values of collector current and applied gate-emitter voltage.
Current - Collector Cutoff (Max): Characterizes current flow through a device’s collector terminal when the device is in an “off” state.
Input Capacitance (Cies) @ Vce: Characterizes the sum of a device’s gate-collector and gate-emitter capacitances, measured with the indicated collector-emitter bias applied.
Input: Indicates which type of input voltage the device is designed to accept.
NTC Thermistor: Indicates whether or not a device incorporates an NTC thermistor to facilitate monitoring of device temperature.
ProductExamples
| MFR PART # | IXXN110N65B4H1 |
| DIGIKEY PART # | IXXN110N65B4H1-ND |
| MANUFACTURER | IXYS |
| DESCRIPTION | IGBT Module PT Single 650 V 215 A 750 W Chassis Mount SOT-227B |
| MFR PART # | FZ400R12KE4HOSA1 |
| DIGIKEY PART # | FZ400R12KE4HOSA1-ND |
| MANUFACTURER | Infineon Technologies |
| DESCRIPTION | IGBT Module Trench Field Stop Single 1200 V 400 A 2400 W Chassis Mount Module |
| MFR PART # | NXH450B100H4Q2F2PG |
| DIGIKEY PART # | 488-NXH450B100H4Q2F2PG-ND |
| MANUFACTURER | onsemi |
| DESCRIPTION | IGBT Module 2 Independent 1000 V 101 A 234 W Chassis Mount 56-PIM (93x47) |
| MFR PART # | APTGT200DU120G |
| DIGIKEY PART # | APTGT200DU120G-ND |
| MANUFACTURER | Microchip Technology |
| DESCRIPTION | IGBT Module Trench Field Stop Dual, Common Source 1200 V 280 A 890 W Chassis Mount SP6 |
SchematicSymbol
MediaLinks
Videos
EconoDUAL™ with TRENCHSTOP™ IGBT7 | DigiKey
ROHM Intelligent Power Modules | DigiKey Daily
Articles
Understanding IGBT Data Sheet Parameters - Bourns
BLDC Motor Control with Integrated IGBT Drivers
Process Enhancements Increase IGBT Efficiency for Motor Drive Applications
IGBTs Boost Solar Panel Efficiency
Product Training Modules
SiC Power Module - ROHM
NX-Series of IGBTs - Powerex
TechForum
How to Find Replacement BJT, MOSFET, and IGBT Transistors
Gate Driver Component Selection
