This Product Selection Guide contains information to help select products in the Power Driver Modules category on DigiKey.com
Power driver modules provide the physical containment for power components, usually IGBTs and MOSFETs in a half bridge or one-, two- or three-phase configurations. Power semiconductors or dies are soldered or sintered on a substrate that carries the power semiconductors and provides electrical and thermal contact and electrical insulation where needed. Power modules provide a higher power density and are in many cases more reliable and easier to cool.
SelectionCharacteristics
Type: Indicates which common transistor technology forms the basis for the device, determining its overall behavior.
Configuration: Defines the internal circuit pattern and connections of the driver.
Current: This rating indicates the nominal amount of output current you would expect the device to provide during normal operation.
Voltage: This rating indicates the nominal amount of output voltage you would expect the device to provide during normal operation.
Voltage - Isolation: The maximum voltage difference that can be observed across the device’s isolation barrier before breakdown occurs and isolation is lost.
ProductExamples
| MFR PART # | NFAQ1560R43TL |
| DIGIKEY PART # | 488-NFAQ1560R43TL-ND |
| MANUFACTURER | onsemi |
| DESCRIPTION | Power Driver Module IGBT 3 Phase Inverter 600 V 15 A 38-PowerDIP Module (0.610", 24.00mm), 24 Leads |
| MFR PART # | AOZ5311NQI_2 |
| DIGIKEY PART # | 785-AOZ5311NQI_2TR-ND - Tape & Reel (TR) |
| MANUFACTURER | Alpha & Omega Semiconductor Inc. |
| DESCRIPTION | Power Driver Module MOSFET 1 Phase 50 A 31-PowerVFQFN Module |
| MFR PART # | STGIPN3H60AT |
| DIGIKEY PART # | 497-16004-5-ND |
| MANUFACTURER | STMicroelectronics |
| DESCRIPTION | Power Driver Module IGBT 3 Phase Inverter 600 V 3 A 26-PowerDIP Module (0.846", 21.48mm) |
| MFR PART # | FF450R08A03P2XKSA1 |
| DIGIKEY PART # | 448-FF450R08A03P2XKSA1-ND |
| MANUFACTURER | Infineon Technologies |
| DESCRIPTION | Power Driver Module IGBT Half Bridge 750 V 450 A Module |
MediaLinks
Articles
Integrated IGBT Modules Simplify Power Management
TechForum
