This Product Selection Guide contains information to help select products in the Gate Drivers category on DigiKey.com
Gate driver Power Management Integrated Circuits (PMICs) are devices that provide isolation, amplification, reference shifting, bootstrapping, or other functions necessary to interface signals from a control device in a power conversion application to the semiconductor devices (usually FETs or IGBTs) through which the power being controlled passes. The exact functions offered by any particular device vary but correlate with the semiconductor configuration it is adapted to drive.
SelectionCharacteristics
DigiKey Programmable: For verified products, DigiKey can program/flash your compiled code or configuration variables prior to shipping. For unverified products, please inquire with ProgCent.Techs@digikey.com
Driven Configuration: Indicates the switch topologies with which a device is intended for use.
Channel Type: Describes device design in terms of control input scheme and the manner in which external controlled devices are controlled.
Number of Drivers: The number of individual driver circuits bundled into a single given device package.
Gate Type: Indicates the type(s) of external transistor that a device is intended to drive.
Voltage - Supply: Typically represented by a range, this indicates the low and high voltage limits that one can expect in standard operation. Voltages outside this range may damage the device and other system components.
Logic Voltage - VIL, VIH: Describes logic input threshold voltages; interpretation may vary due to differences in manufacturer’s characterization practices.
Current - Peak Output (Source, Sink): The maximum output current a part is capable of delivering to/drawing from a load, under the manufacturer’s stated test conditions.
Input Type: The signal methodology used to control the device.
High Side Voltage - Max (Bootstrap): The maximum permissible voltage between a high-side output drive and the IC’s GND/common pin. Essentially, the maximum voltage switchable by a circuit incorporating a given device.
Rise / Fall Time (Typ): Characterizes the amount of time required for a device output to transition from low to high/high to low states, which are commonly defined as 10% and 90% of the supply voltage that powers the output being measured.
Supplier Device Package: This is what the manufacturer calls the package of this device. They are manufacturer specific. It is typically best to use the actual dimensions from the datasheets rather than use this terminology when designing your circuit.
ProductExamples
| MFR PART # | UP1966E |
| DIGIKEY PART # | 917-UP1966ETR-ND - Tape & Reel (TR) |
| MANUFACTURER | EPC |
| DESCRIPTION | Half-Bridge Gate Driver IC Non-Inverting 12-WLCSP-B (1.6x1.6) |
| MFR PART # | ZXGD3009E6TA |
| DIGIKEY PART # | ZXGD3009E6TADITR-ND - Tape & Reel (TR) |
| MANUFACTURER | Diodes Incorporated |
| DESCRIPTION | Low-Side Gate Driver IC Non-Inverting SOT-26 |
| MFR PART # | ADP3120AJCPZ-RL |
| DIGIKEY PART # | ADP3120AJCPZ-RLTR-ND - Tape & Reel (TR) |
| MANUFACTURER | onsemi |
| DESCRIPTION | Half-Bridge Gate Driver IC Inverting, Non-Inverting 8-DFN (3x3) |
| MFR PART # | IXDN602PI |
| DIGIKEY PART # | CLA355-ND |
| MANUFACTURER | IXYS Integrated Circuits Division |
| DESCRIPTION | Low-Side Gate Driver IC Non-Inverting 8-DIP |
MediaLinks
Videos
Videos on Gate Drivers
Articles
Integrated Gate Drivers Reduce BLDC Footprint
High-Efficiency Gate Drivers Play Key Role
BLDC Motor Control with Integrated IGBT Drivers
More Articles on Gate Drivers
Product Training Modules
SiC Gate Drivers - ON Semiconductor
Gate Drivers Overview - STMicroelectronics
Isolated and Non-Isolated Gate Drivers - ROHM
More Product Training Modules on Gate Drivers
Blogs
Power GaN Products Resources DigiKey
Switch Mode Power Supply Matrix – Webinar
More Blogs on Gate Drivers
TechForum
Gate Driver Component Selection
More TechForum Posts on Gate Drivers
