This Product Selection Guide contains information to help select products in the Full Half-Bridge Drivers category on DigiKey.com
Devices in the bridge driver PMIC (Power Management Integrated Circuit) family incorporate two or more power transistors along with circuitry required to operate them as switches under the control of an external device. The transistors are typically configured internally in series-connected pairs known as half-bridges, such that the junction between any given pair can be connected to either of two power supply rails. They are commonly used to translate low-level signals provided by a control device such as a microcontroller into the higher power signals required to operate an actuator such as a stepper or brushless motor.
SelectionCharacteristics
Output Configuration: Indicates the circuit pattern of the device’s output, and how many outputs it has available.
Applications: Application is the type of equipment or environment the device will be used in, typically they are tested and rated by a third party to ensure certain minimum standards for the application they are intended for.
Interface: Indication of which interface(s) or protocol(s) are used by the device to communicate with other components in the system.
Load Type: Indicates which type of current draw the device is designed to interface with and thus the load parameters it’s able to accept.
Technology: Defines the primary construction style of the device, indicating which type of part it is and determining its general usage.
Rds On (Typ): Manufacturer’s characterization of device on-state resistance(s). See datasheets for applicable test conditions.
Current - Output / Channel: Typically this indicates the maximum current each output channel can continuously provide.
Current - Peak Output: The maximum current a device can deliver to a connected load for a brief period of time, measured under manufacturer-defined test conditions.
Voltage - Supply: Typically represented by a range, this indicates the low and high voltage limits which one can expect standard operation. Voltages outside this range may damage the device and other system components.
Voltage - Load: Indicates the maximum voltage that can be controlled by a device’s output stage; may be distinct and different from that which is required for powering a device’s internal workings.
Features: These are different capabilities or properties of the device such as auto restart or an internal oscillator.
Fault Protection: Enumerates protection features incorporated by a device and/or operational hazards against which a device is protected in some manner.
Mounting Type: Indicates how a device is attached.
Supplier Device Package: This is what the manufacturer calls the package of this device. They are manufacturer specific. It is typically best to use the actual dimensions from the datasheets rather than use this terminology when designing your circuit.
ProductExamples
| MFR PART # | EPC23101ENGRT |
| DIGIKEY PART # | 917-EPC23101ENGRTTR-ND - Tape & Reel (TR) |
| MANUFACTURER | EPC |
| DESCRIPTION | Half Bridge Driver General Purpose Gallium Nitride (GaN) FETs 14-QFN (3.5x5) |
| MFR PART # | IFX9201SGAUMA1 |
| DIGIKEY PART # | IFX9201SGAUMA1TR-ND - Tape & Reel (TR) |
| MANUFACTURER | Infineon Technologies |
| DESCRIPTION | Half Bridge (2) Driver DC Motors, General Purpose Power MOSFET PG-DSO-12-17 |
| MFR PART # | L298HN |
| DIGIKEY PART # | 497-2940-5-ND |
| MANUFACTURER | STMicroelectronics |
| DESCRIPTION | Half Bridge (4) Driver DC Motors, Relays, Solenoids, Stepper Motors Bipolar 15-Multiwatt |
| MFR PART # | ISL55110IRZ-T7A |
| DIGIKEY PART # | ISL55110IRZ-T7ATR-ND - Tape & Reel (TR) |
| MANUFACTURER | Renesas Electronics America Inc |
| DESCRIPTION | Half Bridge (2) Driver Digital Imaging Power MOSFET 16-QFN (4x4) |
MediaLinks
Videos
How to Control H-Bridges – Maker.io Tutorial
Stepper Motors - Tech Basics
How to Use a 1-Click Motor Controller with DK IoT Studio – Maker.io Tutorial
Articles
Creating a Miniaturized Analog Controlled Servo | DigiKey
High-Efficiency Gate Drivers Play Key Role
More Articles on H Bridge Drivers
Product Training Modules
MAX256 3W H-Bridge Transformer Driver - Maxim
H-Bridge Drivers - ROHM
H-Bridge Motor Control with Automotive Smart Power
VIPower H-Bridges - STMicro
Blogs
PWM ICs Control Deadtime in 48 V Power Converters
How to Use a 1 Click Motor Controller with Atmosphere IoT Studio
TechForum
Brushed DC Motor Control Using an MDD3A H-bridge Featuring FreeRTOS and the Arduino C33
How to Drive a Stepper Motor
