This Product Selection Guide contains information to help select products in the Laser Drivers category on DigiKey.com
Laser Driver power management integrated circuits (PMICs) provide one or more controlled current sources for supplying semiconductor laser devices from a nominally constant-voltage power source. Commonly including a feature to enable feedback derived from the monitoring of the optical power emitted by the driven laser device, they are widely used in optical communications systems. They are differentiated from devices that perform a similar function by a capacity for high-frequency modulation of the current supplied to the powered device.
SelectionCharacteristics
Data Rate: Indicates the maximum communication speed of the device.
Number of Channels: Indicates the number of independent channels available in the device.
Voltage - Supply: Typically represented by a range, this indicates the low and high voltage limits that one can expect in standard operation. Voltages outside this range may damage the device and other system components.
Current - Supply: This represents the maximum current to which a device will meet its given specifications. Exceeding this current may damage the device and/or other system components.
Current - Modulation: Maximum drive current modulation amplitude for which the device can be configured.
Current - Bias: Maximum steady-state output current for which the driver can be configured.
Supplier Device Package: This is what the manufacturer calls the package of this device. They are manufacturer specific. It is typically best to use the actual dimensions from the datasheets rather than use this terminology when designing your circuit.
ProductExamples
| MFR PART # | EPC21701 |
| DIGIKEY PART # | 917-EPC21701TR-ND - Tape & Reel (TR) |
| MANUFACTURER | EPC |
| DESCRIPTION | Laser Driver IC 1 Channel 80V |
| MFR PART # | MAX3738ETG+T |
| DIGIKEY PART # | MAX3738ETG+TR-ND - Tape & Reel (TR) |
| MANUFACTURER | Analog Devices Inc./Maxim Integrated |
| DESCRIPTION | Laser Driver IC 4.25Gbps 1 Channel 2.97V ~ 3.63V 24-TQFN (4x4) |
| MFR PART # | SY88822VKG |
| DIGIKEY PART # | 576-2070-5-ND |
| MANUFACTURER | Microchip Technology |
| DESCRIPTION | Laser Driver IC 155Mbps 1 Channel 3V ~ 3.6V, 4.5V ~ 5.5V 10-MSOP |
| MFR PART # | ISL58315CRTZ-T7 |
| DIGIKEY PART # | ISL58315CRTZ-T7-ND - Tape & Reel (TR) |
| MANUFACTURER | Renesas Electronics America Inc |
| DESCRIPTION | Laser Driver IC 300MHz 3 Channel 3.3V 40-TQFN (5x5) |
MediaLinks
Articles
Fiber Optics for Radios
Optimizing Optical-Module Performance
More Articles on Laser Drivers
Blogs
Lets Make a Robot MOVE with the Microbit
