This Product Selection Guide contains information to help select products in the IGBT Arrays category on DigiKey.com
Insulated-gate bipolar transistors (IGBTs) are high efficiency and fast switching three-terminal power semiconductor devices primarily used as electronic switches. They are used in switching power supplies in high power applications such as variable-frequency drives (VFDs), electric cars, trains, lamp ballasts, and air-conditioners as well as in switching amplifiers – sound systems and industrial control systems. IGBT arrays contain multiple devices in one package in full- or half-bridge configurations.
SelectionCharacteristics
IGBT Type: Indicates distinctions of internal device construction that influence tradeoffs among various aspects of device performance.
Configuration: Indicates which drive archetype the array is designed to use.
Voltage - Collector Emitter Breakdown (Max): Characterizes current flow through a device’s collector terminal when the device is in an “off” state.
Current - Collector (Ic) (Max): The maximum current value the device can sustain at its collector without risking damage.
Power - Max: Typically this represents the maximum power rating to which a device will meet its given specifications. Exceeding this power rating may damage the device and other system components.
Vce(on) (Max) @ Vge, Ic: Characterizes the maximum voltage that appears across a device’s collector and emitter terminals, measured with the indicated values of collector current and applied gate-emitter voltage.
Current - Collector Cutoff (Max): Characterizes current flow through a device’s collector terminal when the device is in an “off” state.
Input Capacitance (Cies) @ Vce: Characterizes the sum of a device’s gate-collector and gate-emitter capacitances, measured with the indicated collector-emitter bias applied.
Mounting Type: Indicates how the device is mounted.
ProductExamples
| MFR PART # | MMIX4B20N300 |
| DIGIKEY PART # | MMIX4B20N300-ND |
| MANUFACTURER | IXYS |
| DESCRIPTION | IGBT Array Full Bridge 3000 V 34 A 150 W Surface Mount 24-SMPD |
SchematicSymbol
MediaLinks
Videos
650V, 1200V IGBT - MCC’s IGBT offer low conduction loss
Introduction to TRENCHSTOP™ IGBT 7
Articles
Understanding IGBT Data Sheet Parameters - Bourns
Introduction of Field-Stop Shorted-Anode IGBT
BLDC Motor Control with Integrated IGBT Drivers
Process Enhancements Increase IGBT Efficiency for Motor Drive Applications
IGBTs Boost Solar Panel Efficiency
Product Training Modules
IGBT Primer Device - Infineon
IGBT and SLLIMM IPM - STMicroelectronics
Insulated Gate Bipolar Transistors Overview - ROHM
TRENCHSTOP™ 5 Family - Infineon
TechForum
How to Find Replacement BJT, MOSFET, and IGBT Transistors
Gate Driver Component Selection
