This Product Selection Guide contains information to help select products in the Signal Buffers, Repeaters, Splitters category on DigiKey.com
Products within the signal buffer, repeater, and splitter family are used in context of transmitting digital information over electrically long interconnects or cable systems. Primarily used to address the analog considerations imposed on this task by the non-ideal nature of all real-world interconnect systems, they may also provide functions such as translation between different physical interface styles and multiplexing.
SelectionCharacteristics
Applications: Application is the type of equipment or environment the device will be used in, typically they are tested and rated by a third party to ensure certain minimum standards for the application they are intended for.
Input: Enumerates the supported formats for clock/timing signals input to a device.
Output: Indicates the signal format or formats the device is capable of providing on its output points.
Data Rate (Max): Characterizes the maximum rate at which information can be transmitted or received by a device. Does not necessarily refer to throughput rate for user data, see device datasheets for further information.
Number of Channels: Indicates the number of different, separated output points the device provides.
Delay Time: Characterizes the delay in signal propagation introduced by a device.
Signal Conditioning: Enumerates device features capable of manipulating a signal for the purpose of preserving the information contained therein.
Capacitance - Input: Characterizes the amount of capacitance that exists between a given signal input pin and ground pin on the device.
Voltage - Supply: Typically represented by a range, this indicates the low and high voltage limits which one can expect standard operation. Voltages outside this range may damage the device and other system components.
Current - Supply: This represents the maximum current to which a device will meet its given specifications. Exceeding this current may damage the device and/or other system components.
Mounting Type: Indicates how the device is mounted.
ProductExamples
| MFR PART # | LTC4311CSC6#TRPBF |
| DIGIKEY PART # | LTC4311CSC6#TRPBFTR-ND - Tape & Reel (TR) |
| MANUFACTURER | Analog Devices Inc. |
| DESCRIPTION | Accelerator 1 Channel 400kHz SC-70-6 |
| MFR PART # | PI3EQX16904GLZHEX |
| DIGIKEY PART # | PI3EQX16904GLZHEXDITR-ND - Tape & Reel (TR) |
| MANUFACTURER | Diodes Incorporated |
| DESCRIPTION | Buffer, ReDriver 4 Channel 16Gbps 42-TQFN (9x3.5) |
| MFR PART # | P82B715P |
| DIGIKEY PART # | 296-23469-5-ND |
| MANUFACTURER | Texas Instruments |
| DESCRIPTION | Buffer, ReDriver 1 Channel 8-PDIP |
| MFR PART # | PI6ULS5V9617AUEX |
| DIGIKEY PART # | PI6ULS5V9617AUEXDITR-ND - Tape & Reel (TR) |
| DESCRIPTION | Buffer, ReDriver 2 Channel 8-MSOP |
