This Product Selection Guide contains information to help select products in the Shock Sensors category on DigiKey.com
Shock Sensors are designed to detect and respond to the presence of a sudden change in acceleration, most often using piezoelectric principles. The characteristics are sensor type, sensing range, sensitivity, and mounting type. The sensor types are ball and vibration (Piezo film) with a sensing range of 0 to 1500 G, and sensitivities of 0.055 pC/G, 0.09 pC/G, 0.350 pC/G, 0.608 pC/G, 0.840 pC/G, or 1 mV/G.
SelectionCharacteristics
Sensor Type: Method by which the sensor measures its data.
Sensing Range: Indicates the range(s) of a physical input quantity over which a device is capable of producing a valid measurement.
Sensitivity: Typically, this would indicate the change in output corresponding to a set change in input. For example, a device with a sensitivity of .608pC/G, the output will change by .608 pico Coulombs for every change of 1G in input.
Output Type: Indicates the type of electrical signal the device provides, such as voltage.
Termination: Selection of termination style used to connect the device to a system.
ProductExamples
| MFR PART # | SK-SHOCK-AX-3Ds-2-4-8g |
| DIGIKEY PART # | 3925-SK-SHOCK-AX-3Ds-2-4-8g-ND |
| MANUFACTURER | Beanair Sensors |
| DESCRIPTION | Vibration Shock Sensor ± |
MediaLinks
Articles
Fundamentals of Piezoelectric Shock and Vibration Sensors
