This Product Selection Guide contains information to help select products in the Battery Chargers category on DigiKey.com
Battery Charger PMICs (Power Management Integrated Circuits) are a family of component-level products used to implement battery charge control and charge management functions in electronic devices. Classified primarily by the battery chemistry and number of cells with which a device is designed for use, these devices provide current or voltage regulation and monitoring functions necessary for safe recharging of electrochemical cells and supercapacitors.
SelectionCharacteristics
Battery Chemistry: Indicates the chemical system(s) of batteries or cells for which a device is designed to be compatible.
Number of Cells: Indicates the quantity of cells of the specified size or type that are accommodated by a product.
Current - Charging: Describes mode(s) of charge delivery.
Programmable Features: Indicates charge cycle parameters that are user-configurable for a given device.
Fault Protection: Enumerates protection features incorporated by a device and/or operational hazards against which a device is protected in some manner.
Charge Current - Max: Indicates the rated maximum output current of a device.
Battery Pack Voltage: The nominal or maximum voltage of the battery packs with which a device is suitable for use.
Voltage - Supply (Max): Typically represented by a range, this indicates the low and high voltage limits which one can expect standard operation. Voltages outside this range may damage the device and other system components.
Interface: Indication of which interface(s) or protocol(s) are used by the device to communicate with other components in the system.
ProductExamples
| MFR PART # | MCP73811T-420I/OT |
| DIGI-KEY PART # | MCP73811T-420I/OTTR-ND - Tape & Reel (TR) |
| MANUFACTURER | Microchip Technology |
| DESCRIPTION | Charger IC Lithium Ion/Polymer SOT-23-5 |
| MFR PART # | XC6804A4E14R-G |
| DIGIKEY PART # | 893-1312-2-ND - Tape & Reel (TR) |
| MANUFACTURER | Torex Semiconductor Ltd |
| DESCRIPTION | Charger IC Lithium Ion/Polymer 6-USPEL (1.8x2) |
| MFR PART # | MAX713CPE+ |
| DIGIKEY PART # | MAX713CPE±ND |
| MANUFACTURER | Analog Devices Inc./Maxim Integrated |
| DESCRIPTION | Charger IC Multi-Chemistry 16-PDIP |
| MFR PART # | STNS01PUR |
| DIGIKEY PART # | 497-13880-2-ND - Tape & Reel (TR) |
| MANUFACTURER | STMicroelectronics |
| DESCRIPTION | Charger IC Lithium Ion 12-DFN (3x3) |
MediaLinks
Videos
How does mobile phone fast charging work?
Articles
Designing a High-Efficiency Solar Power
Use The Right ICs to Extend Battery Life
A Designer’s Guide to Lithium Ion (Li-ion) Battery Charging
Implementing Fast Charging with an Adaptive USB-C
Blogs
Charging Lithium Iron Phosphate Batteries
