This Product Selection Guide contains information to help select products in the Battery Management category on DigiKey.com
Products in the Battery Management PMIC (Power Management Integrated Circuit) family are used for battery-related monitoring and control functions including authentication, cell balancing, condition monitoring, fuel gauging, source selection, short circuit protection, over- and under-voltage protection, and others. Note that while some products in this family may include a battery charging function among their features, products implementing a charging function as a principle feature are classified separately.
SelectionCharacteristics
Function: Indicates the primary functionality of the device and what its purpose in the circuit is.
Battery Chemistry: Indicates the chemical system(s) of batteries or cells for which a device is designed to be compatible.
Number of Cells: Indicates the quantity of cells of the specified size or type that are accommodated by a product.
Fault Protection: Enumerates protection features incorporated by a device and/or operational hazards against which a device is protected in some manner.
Interface: Indication of which interface(s) or protocol(s) are used by the device to communicate with other components in the system.
ProductExamples
| MFR PART # | MAX17262REWL+T |
| DIGIKEY PART # | 175-MAX17262REWL+TTR-ND - Tape & Reel (TR) |
| MANUFACTURER | Analog Devices Inc./Maxim Integrated |
| DESCRIPTION | Battery Fuel Gauge IC LiFePO4/Li-ion 9-WLP (1.47x1.45) |
| MFR PART # | STC3115AIQT |
| DIGIKEY PART # | 497-15077-2-ND - Tape & Reel (TR) |
| MANUFACTURER | STMicroelectronics |
| DESCRIPTION | Battery Battery Monitor IC 10-DFN (3x2) |
| MFR PART # | MM3513C01NRH |
| DIGIKEY PART # | 2508-MM3513C01NRHTR-ND - Tape & Reel (TR) |
| MANUFACTURER | Mitsumi Electric Company Ltd |
| DESCRIPTION | Battery Battery Monitor IC Lithium Ion/Polymer SOT-25A |
| MFR PART # | AP9214LA-AH-HSB-7 |
| DIGIKEY PART # | AP9214LA-AH-HSB-7DITR-ND - Tape & Reel (TR) |
| MANUFACTURER | Diodes Incorporated |
| DESCRIPTION | Battery Battery Protection IC Lithium Ion/Polymer U-DFN2535-6 |
MediaLinks
Articles
Monitoring Stacked Cells with BMICs
Monitoring Battery Stacks in Remote Applications
Blogs
Count those Coulombs for Lithium Battery Fitness!
