This Product Selection Guide contains information to help select products in the RMS to DC Converters category on DigiKey.com
Products in the RMS-to-DC converter family are used to perform a mathematical function of measuring a time-varying waveform and return a value proportional to the equivalent steady state (DC) value that would result in producing the same power dissipation if applied to a resistive load. Often used for measurements in AC power-related applications, they are differentiated among themselves and from other techniques used for similar ends by the degree of accuracy in the result given when the input is a non-sinusoidal waveform.
SelectionCharacteristics
Current - Supply: This represents the maximum current to which a device will meet its given specifications. Exceeding this current may damage the device and/or other system components.
Voltage - Supply: Typically represented by a range, this indicates the low and high voltage limits which one can expect standard operation. Voltages outside this range may damage the device and other system components.
ProductExamples
| MFR PART # | LTC1967CMS8#TRPBF |
| DIGIKEY PART # | LTC1967CMS8#TRPBFTR-ND - Tape & Reel (TR) |
| MANUFACTURER | Analog Devices Inc. |
| DESCRIPTION | RMS to DC Converter 8-MSOP |
| MFR PART # | AD536AKHZ |
| DIGIKEY PART # | AD536AKHZ-ND |
| DESCRIPTION | RMS to DC Converter TO-100-10 |
| MFR PART # | AD8436ACPZ-WP |
| DIGIKEY PART # | AD8436ACPZ-WP-ND |
| DESCRIPTION | RMS to DC Converter 20-LFCSP (4x4) |
| MFR PART # | AD737JNZ |
| DIGIKEY PART # | AD737JNZ-ND |
| DESCRIPTION | RMS to DC Converter 8-PDIP |
MediaLinks
Articles
Monitoring Signal Voltage/Power RMS-to-DC
RF Power Measurement Using RMS Detectors
Product Training Modules
Analog RMS-to-DC Technology: Converters and Applications
