This Product Selection Guide contains information to help select products in the Triac, SCR Output Optoisolators category on DigiKey.com
Triac and SCR output optoisolators allow bi-directional or unidirectional control of an AC (alternating current) source while providing isolation between the control and load circuits. An LED is optically coupled to a photodiode in a single device package. The photodiode controls the gate of the Triac or SCR and may include zero cross circuity. These optoisolators are selected by on-state current, forward voltage, turn on time, and mounting type.
SelectionCharacteristics
Output Type: Indicates which signal type the device outputs.
Zero Crossing Circuit: Indicates whether or not a device contains circuitry to inhibit triggering when the voltage present across the output terminals exceeds a manufacturer-defined threshold.
Number of Channels: The number of separate isolation channels available within the device.
Voltage - Isolation: The maximum voltage difference that can be observed across the device’s isolation barrier before breakdown occurs and isolation is lost.
Voltage - Off State: Indicates the maximum instantaneous voltage that may be repetitively/continuously applied to a device in a non-conducting state without causing damage.
Static dV/dt (Min): Characterizes resistance to false triggering; the minimum time rate of voltage change across the device output that a fully-commutated device must withstand under manufacturer-defined test conditions.
Current - LED Trigger (Ift) (Max): Input current required to trigger output into a latched conducting state, actual values vary with temperature.
Current - On State (It (RMS)) (Max): The rated maximum RMS (root mean square) current carrying capacity of a device, typically specified for sinusoidal current waveforms at 50/60 Hz.
Current - Hold (Ih): Characterizes the minimum current flow through a device’s output that will maintain the output in a conducting state.
Turn On Time: Characterizes the time delay between application of a control input and the device output achieving an ‘On’ state.
Voltage - Forward (Vf) (Typ): Characterizes the device’s forward voltage drop across its internal diodes while in an ‘Off’ state.
Current - DC Forward (If) (Max): Characterizes the device’s forward current through its internal diodes while in an ‘On’ state.
Approval Agency: An indication that the product meets the minimum safety standards of an approving agency. These agencies are either government entities or private third-party labs that protect consumer safety.
ProductExamples
| MFR PART # | TLP266J(T7-TPL,E |
| DIGIKEY PART # | TLP266J(T7-TPLETR-ND - Tape & Reel (TR) |
| MANUFACTURER | Toshiba Semiconductor and Storage |
| DESCRIPTION | Optoisolator Triac Output 3750Vrms 1 Channel 6-SOP |
| MFR PART # | VO2223A |
| DIGIKEY PART # | 751-1490-5-ND |
| MANUFACTURER | Vishay Semiconductor Opto Division |
| DESCRIPTION | Optoisolator Triac, Power Output 5300Vrms 1 Channel 8-DIP |
| MFR PART # | MOC3023SR2M |
| DIGIKEY PART # | MOC3023SR2MTR-ND - Tape & Reel (TR) |
| MANUFACTURER | onsemi |
| DESCRIPTION | Optoisolator Triac Output 4170Vrms 1 Channel 6-SMD |
| MFR PART # | MOC3043M |
| DIGIKEY PART # | MOC3043M-ND |
| DESCRIPTION | Optoisolator Triac Output 4170Vrms 1 Channel 6-DIP |
SchematicSymbol
MediaLinks
Videos
Articles
Galvanic Isolation for IoT Sensors
Linear Optical Isolation for Safe Sensor Operation
Product Training Modules
Introduction to Optoisolators - TT Electronics
