This Product Selection Guide contains information to help select products in the Fan Accessories category on DigiKey.com
Products within this family are ancillary to or supportive of the use of fans, blowers, or other air moving devices. Included items range from mounting brackets and screws to vibration-isolating mounts to drive/control electronics, air flow switches, electrical connectors, lead wire sets, and others. Similar items of particular commonality including finger guards, filters, and cord sets are specifically excluded and grouped separately.
SelectionCharacteristics
Fan Accessory Type: The type, style, or nature of the accessory.
Fits Fan Size: The dimensions of the fan that this accessory is designed for.
Length: Indicates the overall length of the part.
ProductExamples
| MFR PART # | AFM-120NO |
| DIGIKEY PART # | 1053-1581-ND |
| MANUFACTURER | Orion Fans |
| DESCRIPTION | AIR FLOW SWITCH W/120MM GUARD NO |
| MFR PART # | VI-1 |
| DIGIKEY PART # | 1570-1265-ND |
| MANUFACTURER | Mechatronics Fan Group |
| DESCRIPTION | FAN VIBRATION ISOLATOR |
| MFR PART # | AFM-01NC |
| DIGIKEY PART # | 1053-1578-ND |
| DESCRIPTION | AIR FLOW SWITCH NC |
