This Product Selection Guide contains information to help select products in the Thermal Accessories category on DigiKey.com
Thermal Accessories are supplementary items used with thermal products. The accessory types are adapter, alignment pad, base assembly, booklet, bypass kit, clamp, clips, cam, connector kit, flame barrier, flexible insulation, flexible heater assembly, grommet, gun manual, heat director/transfer, heat sink (clip, support kit, turbulator, u-joint), I connector, installation and removal tool, insulating washer, insulator, L-joint, mounting kit, nipple, nozzle, NTC sensor, pin and spring assembly, push pin, replacement sensor, retainer clip, solder anchor, spring, spring latch clip, temperature controller, temperature sensor wire, tubing, and wireless power generator.
SelectionCharacteristics
Accessory Type: The type, style, or nature of the accessory.
ProductExamples
| MFR PART # | TC-XX-PR-59 |
| DIGIKEY PART # | 926-1066-ND |
| MANUFACTURER | Laird Thermal Systems, Inc. |
| DESCRIPTION | THERMOELECT MOD TEMP CNTRL |
| MFR PART # | MGT270 |
| DIGIKEY PART # | ATS1386-ND |
| MANUFACTURER | Advanced Thermal Solutions Inc. |
| DESCRIPTION | TOOL FOR MAXI GRIP 27X27 |
| MFR PART # | CLA-TO-21E |
| DIGIKEY PART # | CLA-TO-21E-ND |
| MANUFACTURER | Ohmite |
| DESCRIPTION | CAM CLIP FOR TO DEVICES |
