This Product Selection Guide contains information to help select products in the Circuit Protection Accessories category on DigiKey.com
Supplementary items used with other devices in this category.
SelectionCharacteristics
Accessory Type: The type, style, or nature of the accessory.
ProductExamples
| MFR PART # |
65900000009 |
| DIGIKEY PART # |
WK6246-ND |
| MANUFACTURER |
Littelfuse Inc. |
| DESCRIPTION |
COVER FUSE TRANSPRNT FOR 656/658 |
| DATASHEET |
Click Here |
| MFR PART # |
BK/1A4806-2 |
| DIGIKEY PART # |
283-4903-ND |
| MANUFACTURER |
Eaton - Electronics Division |
| DESCRIPTION |
METAL NUT W/CUT OUT |
| DATASHEET |
Click Here |
| MFR PART # |
HE1070 |
| DIGIKEY PART # |
335-1027-ND |
| MANUFACTURER |
APM Hexseal |
| DESCRIPTION |
BOOT CIRCUIT BREAKER 3POLE CLEAR |
| DATASHEET |
Click Here |
| MFR PART # |
190430011 |
| DIGIKEY PART # |
WM13613-ND |
| MANUFACTURER |
Molex |
| DESCRIPTION |
FUSE BLOCK TAP ADAPTER (FTA-1) |
| DATASHEET |
Click Here |
| MFR PART # |
P50UB |
| DIGIKEY PART # |
1920-1425-ND |
| MANUFACTURER |
Altech Corporation |
| DESCRIPTION |
BUSBAR DIRECT POWER FEED |
| DATASHEET |
Click Here |
| MFR PART # |
2817741 |
| DIGIKEY PART # |
277-7029-ND |
| MANUFACTURER |
Phoenix Contact |
| DESCRIPTION |
BASE TYPE2 ARRESTERS DIN RAIL |
| DATASHEET |
Click Here |
| MFR PART # |
HF361N |
| DIGIKEY PART # |
3473-HF361N-ND |
| MANUFACTURER |
Siemens |
| DESCRIPTION |
HDSS FUS 3P4W 600V 30A N1 |
| DATASHEET |
Click Here |
| MFR PART # |
31.1811 |
| DIGIKEY PART # |
486-1168-ND |
| MANUFACTURER |
SCHURTER Inc. |
| DESCRIPTION |
FUSECARRIER FEU GRIP BODY 5X20MM |
| DATASHEET |
Click Here |
If you have any general questions on the specifications for selecting Circuit Protection Accessories, please reply using the button below. If you have questions on specific Circuit Protection Accessories please post those questions in the Circuit Protection category.
