This Product Selection Guide contains information to help select products in the Accessories category on DigiKey.com
Supplementary items used with other devices in this category.
SelectionCharacteristics
Accessory Type: The type, style, or nature of the accessory.
ProductExamples
| MFR PART # |
10-BR |
| DIGIKEY PART # |
595-1701-ND |
| MANUFACTURER |
Signal Transformer |
| DESCRIPTION |
BRACKET 1.64" X 1.12" |
| DATASHEET |
Click Here |
| MFR PART # |
2277598 |
| DIGIKEY PART # |
277-17274-ND |
| MANUFACTURER |
Phoenix Contact |
| DESCRIPTION |
DIN RAIL ADAPTER |
| DATASHEET |
Click Here |
| MFR PART # |
1182KIT1500 |
| DIGIKEY PART # |
HM2440-ND |
| MANUFACTURER |
Hammond Manufacturing |
| DESCRIPTION |
TRANSFORMER TOROID HDWE KIT |
| DATASHEET |
Click Here |
| MFR PART # |
2907888 |
| DIGIKEY PART # |
2907888-ND |
| MANUFACTURER |
Phoenix Contact |
| DESCRIPTION |
THE OPTIONAL HOLDING DEVICE ENSU |
| DATASHEET |
Click Here |
| MFR PART # |
PH-31-R |
| DIGIKEY PART # |
582-1045-ND |
| MANUFACTURER |
CR Magnetics Inc. |
| DESCRIPTION |
INDICATOR PANEL SPLASH PROOF RED |
| DATASHEET |
Click Here |
| MFR PART # |
298G4 |
| DIGIKEY PART # |
HM2153-ND |
| MANUFACTURER |
| DESCRIPTION |
CONNECTOR POWER ADAPTER EUROPEAN |
| DATASHEET |
Click Here |
| MFR PART # |
21033012006 |
| DIGIKEY PART # |
1195-7256-ND |
| MANUFACTURER |
HARTING |
| DESCRIPTION |
M12 TRANSF. RECPT. FRONT MOUNTIN |
| DATASHEET |
Click Here |
| MFR PART # |
SP-310 |
| DIGIKEY PART # |
237-1157-ND |
| MANUFACTURER |
Triad Magnetics |
| DESCRIPTION |
TRANSF AUDIO SHIELD |
| DATASHEET |
Click Here |
| MFR PART # |
2700324 |
| DIGIKEY PART # |
277-14637-ND |
| MANUFACTURER |
Phoenix Contact |
| DESCRIPTION |
CONN TERM BLK TRANSF ORAN 4P |
| DATASHEET |
Click Here |
If you have any general questions on the specifications for selecting Accessories please reply using the button below. If you have questions on specific transformer Accessories please post those questions in the Transformers category.
