This Product Selection Guide contains information to help select products in the RFID Accessories category on DigiKey.com
RFID Accessories are supplementary items used with radio frequency identification parts. The accessory types are adapter/USB, adapter cable, amplifier, antenna cable, antenna multiplexer, antenna tuning board, antenna tuning indicator, battery, carrying case, clips, control module, controller, cover, docking station, extension cable, holder, housing, I/O extension board, ID link unit, interface board, interface cable, mount, mounting kit, power adapter, power cord, power splitter, power supply, RS232/RS485 cable, terminal set, transponder sheeting, USB cable, and WLAN-A wireless adapter.
SelectionCharacteristics
Accessory Type: The type, style, or nature of the accessory.
| MFR PART # | 2909681 |
| DIGIKEY PART # | 277-17376-ND |
| MANUFACTURER | Phoenix Contact |
| DESCRIPTION | TWN4 MIFARE NFC USB ADAPTER |
| MFR PART # | 2557.000.00 |
| DIGIKEY PART # | 629-1050-ND |
| MANUFACTURER | FEIG Electronic |
| DESCRIPTION | ID NET.24V-B POWER SUPPLY UNIT |
| MFR PART # | AK-WICON-SXL-POE |
| DIGIKEY PART # | 1851-AK-WICON-SXL-POE-ND |
| MANUFACTURER | AK-Nord GmbH |
| DESCRIPTION | ETHERNET WIEGAND CONVRTR SXL-POE |
| MFR PART # | CAB-14132 |
| DIGIKEY PART # | CAB-14132-ND |
| MANUFACTURER | SparkFun Electronics |
| DESCRIPTION | UHF RFID CABLE (TNC TO SMA) |
| MFR PART # | XGST2BA |
| DIGIKEY PART # | 4008-XGST2BA-ND |
| MANUFACTURER | Schneider Electric |
| DESCRIPTION | RADIO FREQUENCY IDENTIFICATION X |
