Particle, Dust Sensors
This Product Selection Guide contains information to help select products in the Particle, Dust Sensors category on DigiKey.com
Products in the dust sensor family are modular devices used to measure the amount of suspended particulate matter in the ambient air. Used for health and safety applications, clean room monitoring, and similar purposes, the available devices are varied in their sensitivity characteristics, particle classification capabilities, maintenance requirements, and similar details of operation.
SelectionCharacteristics
Type: Indicates the type of sensing technology employed.
Output Type: Indicates the type of electrical signal the device provides, such as I2C or UART.
Sensitivity: Typically, this would indicate the smallest particle detectable by the device. It also sometimes lists the change in output per detection.
Current - DC Forward (If) (Max): Typically this represents the maximum current to which a device will meet its given specifications. Exceeding this current may damage the device and/or other system components.
Voltage - Supply: Typically represented by a range, this indicates the low and high voltage limits that one can expect in standard operation. Voltages outside this range may damage the device and other system components.
ProductExamples
MFR PART # GP2Y1010AU0F
DIGIKEY PART # 1855-1012-ND
MANUFACTURER SHARP/Socle Technology
DESCRIPTION Infrared (IR) Dust Sensor Module, Single Pass Through
DATASHEET Click Here
MFR PART # SPS30
DIGIKEY PART # 1649-1106-ND
MANUFACTURER Sensirion AG
DESCRIPTION Air Sensor Dust Sensor Box
MFR PART # HPMA115C0-003
DIGIKEY PART # 480-HPMA115C0-003-ND
MANUFACTURER Honeywell Sensing and Productivity Solutions
DESCRIPTION Air Sensor Dust Sensor Module
MediaLinks
Videos
Amphenol Advanced Sensors SMART Dust Sensor | Another Geek Moment
Product Training Modules
Introduction to Dust Sensors
If you have any general questions on the specifications for selecting Particle, Dust Sensors, please reply using the button below. If you have questions on specific Particle, Dust Sensors please post those questions in the Sensors Transducers category.
