This Product Selection Guide contains information to help select products in the Photovoltaic (Solar Panel) Connector Accessories category on DigiKey.com
Photovoltaic (Solar Panel) connector accessories are designed to add features, provide protection or adapt between solar panel connector types. Added features may include dust caps, filler and fuse plugs, grounding bolts, clips and lugs, locking collars, latches, junction boxes, safety clips and test plugs. Some accessories provide coding or keying elements such as minus and plus symbols or coloration.
SelectionCharacteristics
Type: The type, style, or nature of the accessory.
Coded, Keyed: Describes polarity markings incorporated into a connector.
Features: These are different capabilities or properties of the device such as wire size or color.
ProductExamples
| MFR PART # | 1785430 |
| DIGIKEY PART # | 277-17207-ND |
| MANUFACTURER | Phoenix Contact |
| DESCRIPTION | Protective Cap Connector Black |
| MFR PART # | 1014455 |
| DIGIKEY PART # | 277-18234-ND |
| DESCRIPTION | Coding Element Connector Blue |
| MFR PART # | 1002290 |
| DIGIKEY PART # | 277-18238-ND |
| DESCRIPTION | Release Latch Connector Green |
