This Product Selection Guide contains information to help select products in the Ground Fault Circuit Interrupter (GFCI) category on DigiKey.com
Ground fault circuit interrupters (GFCI) guard against accidental electrocution by monitoring the current traveling to and from an electrical load. A difference in current greater than 5 mA triggers a manually resettable electrical disconnect which quickly isolates power from the load. GFCIs can be added to existing circuits through in-line splicing, outlet box mounted modules, cord end plugs, or panel mounted sensing modules.
SelectionCharacteristics
Specifications: Defines which line voltage levels the GFCI is designed to monitor and protect.
ProductExamples
| MFR PART # | PGFM-211-B-A1-188 |
| DIGIKEY PART # | 723-1351-ND |
| MANUFACTURER | Sensata-Airpax |
| DESCRIPTION | GFCI Sensing Module |
| MFR PART # | 1301530144 |
| DIGIKEY PART # | 1301530144-ND |
| MANUFACTURER | Molex |
| DESCRIPTION | GFCI Permanent Splice |
| MFR PART # | SB5032-021-0 |
| DIGIKEY PART # | 18-SB5032-021-0-ND |
| MANUFACTURER | Littelfuse Inc. |
| DESCRIPTION | GFCI Outlet Box |
| MFR PART # | 5602192 |
| DIGIKEY PART # | 277-5396-ND |
| MANUFACTURER | Phoenix Contact |
MediaLinks
Articles
Ground Fault Sensing and Protection
