Hi everyone, I’m hoping someone can help me identify this power module so that i can purchase the replacement.
This part is located in my Time Base Corrector system but when i go to plug it into the wall socket, the GFCI outlet trips.
So I’m assuming its this power module that needs replacing.
There are many power modules in this online store and although I can match the 120v and 3A, I think I also need to match the L C C numbers located on this module, and that is where I’m stuck.
I’d be concerned first about something that fits reasonably well. 5120.4073.0 is the closest I’m finding in stock at this point. It’d be nice to match attenuation curves etc, but in a repair context something close will likely get the job done.
Plus, there’s no guarantee that the pictured unit is at fault, though it’s certainly possible. If the GFCI trips immediately upon being reset with the unit plugged in, that’d be a fair indication that something within the device is leaking from line to ground. Might be within this device, or somewhere farther down.the chain.
