This Product Selection Guide contains information to help select products in the Camera Modules category on DigiKey.com
Camera Modules are ready-to-use modules that include an image sensor, lens, and supporting electronics. These devices can be filtered by color, resolution, shutter type, frames per second, lens mount, and more.
SelectionCharacteristics
Color: Indicates the spectrum(s) of light the device is designed to detect.
Resolution: Indicates the visual resolution of the device, either in standard monitor format or in megapixels.
Frames per Second: Indicates the maximum number of full-frame images per second that an image sensor is capable of transferring.
Shutter: Describes the type of shutter the device uses to let light expose the sensor.
Lens Mount: A callout of the specification for the mount the lens uses.
Sensor: Indicates the specific sensor chip being used.
Type: Indicate the technology being used for the sensing.
Interface: Indication of which interface(s) or protocol(s) are used by the device to communicate with other components in the system.
Pixel Size: Indicates the physical dimensions of the imaging pixel used in the sensor.
Size / Dimension: The physical dimensions of the device. Typically length by width.
Height (Max): Indicates the overall height of the device.
ProductExamples
| MFR PART # | 11888 |
| DIGIKEY PART # | 2285-11888-ND |
| MANUFACTURER | Allied Vision, Inc. |
| DESCRIPTION | CAMERA COLOR CSMNT OPEN AR0135CS |
| MFR PART # | TB-3DCAM-8060-USB |
| DIGIKEY PART # | 3074-TB-3DCAM-8060-USB-ND |
| MANUFACTURER | Terabee SAS |
| DESCRIPTION | TERABEE 3DCAM 80X60 |
| MFR PART # | TOFCAM-611 |
| DIGIKEY PART # | 2199-TOFCAM-611-ND |
| MANUFACTURER | ESPROS Photonics AG |
| DESCRIPTION | MOD TIME OF FLIGHT 3M |
